Bolt
I have over an inch of play in my steering wheel on my F250. I tried cranking down the adjustment screw on the steering box, it may have helped a little, but the play is still mostly there. I put over 2 turns on the set screw, and the most noticeable difference is that it steers a little stiffer now. If I turn the shaft by hand under the hood I can feel the play, it turns real easy until the play is taken up, so I'm thinking it's in the steering box. Any advice? Do I need to replace it? If so, with what? Factory, rebuilt, etc? Does RedHead make boxes this new?
