stealth HPOP issues again!!!
Patrick Feeley
Tehachapi, CA
wich ipr is wich?i remember that on the end that goes into the hpop one of them is closed solid and one has a hole that has a set screw inside of it.i have the one thats open but forget wich one is in the truck and running,but i know its for 96-up.
Looking at the business end of the IPR, the non-edge filter IPR will look like a gun barrel, while the “edge filter” IPR will be solid at the tip. Cheers!
94f450sd
certified nutjob
plymouth,ma
ok well i got running right.the zIPR i had was the right one but no good.got another from the junkyard and stuck it in and it runs fine.thanx guys
94f450sd
certified nutjob
plymouth,ma
she runs sweet now.plenty of low end nut!!0 to 70MPH felt like aBout 4 sconds.will smoke the tires from a dead stop without useing the brakes.happy with it so far.got a few oil leaks i gotta fix thoiugh.gotta come up with the money for some orings for the fittings.
