starting.....
atk
Moderator
simcoe, ontario, canada
since i have had my truck, for about 2 months now, it sometimes starts very easy and sometimes it cranks over longer. is this normal for the 6.0L`s. mind you it is not alot longer. sometimes you turn the key and fires up and sometime turns over 4 to 6 seconds before starting...also i have noticed with other trucks, some seem to run quieter than mine. even sometimes mine seems to run quieter than others. maybe it is just me....what will help to male them run quieter????
new owner paranoia... since youre in canada...im wondering if
it takes longer on COLD mornings or after it sits for several hours ?
The 6.0 does take longer cranking time than the 7.3. This is due to the oil system and the fuel injectors. The truck must build a certain amount of pounds per inch of pressure to fire the injectors.
atk
Moderator
been starting about the same when it is cold, depends how long it has been sitting after it has been at operating temp...i waas just curious....
TacoCat
