Starting problems
nickp3
I have a 99 F-250 4x4 superduty with a 7.3 liter deisel it has 140K miles and I am the original owner. My problem is after my truck has been sitting for more than 8 Hrs or so I have to crank it for a while before it will start then it will usually start for a few seconds then shut off. It is as if it is out of fuel, Is there a check valve that can be leaking or possibly a bad fuel pump. Thanks for any help! Nick
Check the oil level in the high pressure pump reservoir, it sounds lilke you are having a drainback issue.
Tbar
SDD STAFF/Moderator
For reference you would check the cold oil level at the port this hose is screwed into. Don't remember off hand what size plug it is.
Pic
Tbar
nickp3
thanks
I appreciate all the help, how do I Check the oil level in the high pressure pump reservoir, and how do I fix it if it is draining back? I am going to try and work my tranny issue today. I am going to drop the pan and valve body I will let you know how it goes. I work Mids in the Air Force so it will be later on this afternoon before I can start on it. I am stationed in N.C. Thanks again all Nick
P.S. as far as the O-rings the truck has not sat at all and there is no smoke on start up.
TacoCat
