jehlers
After the 30K service at the dealership my 2006 Diesel F450 Duper Duty is VERY cold blooded. - Starts very hard and will barely run for 10-15 minutes.
The only way it will start after more than a day’s rest is to turn on the ignition and let it sit for 1-3 minutes. (You can hear some sort of pump running during this time. - it sounds almost like the A/C fan.) after this stops running and you turn it to off and on about 4-5 times to cycle the glow plugs it will start decently, but don’t even try to drive it for at least 8-10 minutes. it is VERRRY sluggish and will barely shift.
I’ve tried the dealership and they are useless. - I wonder if they caused it?
I checked the filter connections and confirmed they did actually replace the fuel filters.
Ive been just dealing with it for a long time, because after it is up and running there are no issues. but I am sure this just isn't right.
Ideas?
Ideas?
