Start but dies
Log350
Jeddo mi
I have a 07 f350 powerstroke that will start and run for about 5-10 then shut off there's no check engine light the problem happened when I drove it up from Texas had it up in Michigan for a week change the fuel filters ran great for 30 min then shut off on me going down the road please help this is my first diesel
Get it scanned by a good mechanic - rule #1. This will tell you what the computer thinks is wrong and you can go from there. If you plan of buying a scanner get one that can read CAN or it won't see anything. It is OBDII including CAN.
First off, Welcome to SDD.com, glad to have you here. What was the temp up
in Michigan, and were you using treated fuel. Good luck and hope you can find
out what's wrong when you scan your truck.
DogMan66
Knoxville TN
there is a temp sensor in the exhaust system that is out of range. I had the same problem on my 08. I was driving to work no problems and the truck just shut down out of the blue. It sat for 3 hours and would start up and shut down with in minutes.
