Stalls and stops running etc
Hoss 350
My GSP, Dutch
Spokane, WA
Last I checked, at around 7-8 quarts of oil, these trucks will shut down for lack of injector pressure.
Also, the CPS can happen anytime and can be intermittent like that. Top off your oil and change the CPS, then get back to us if it happens again...
viper5035
Persia, IA
i posted in your other thread in the 911 forum and i had the same problem and it was the injector o-rings. changed them out and havent burned any oil since
Update replaced CPS @ dealer under recall but oil level extremely low; eight quarts which effects running of vehicle which you already know. But where is the oil going? No leaks and not going into fuel and exhaust? Sportsnutim:dunno
on a diesel, if it's not leaking externally, it's going down the tailpipe.
Brad1103
