STALLING WHEN COLD!VERY HARD TO RESTART!
mrsurpluse
mrsurpluse
cincinnati
MY F-250 SUPER DUTY 2000 MODEL NORMALLY STARTS UP FINE,BUT IF I DONT LET IT WARM UP 15 MINS. IT WILL STALL AND AFTER CRANKING AND PUMPING THE PEDEL IT WILL RESTART BUT UNLESS YOU LET IT WARM UP ,WILL STALL AGAIN .ONLY RUNS GOOD AFTER THE ENGINE IS WARM.TODAY IT WOULD NOT STAY RUNNING FOR MORE THAN 2MINS.AT A TIME.WEARNG OUT THE STARTER!!!!!!!!!!!!!!!!!!!!!COULD IT BE THE INJECTOR PUMP?OR BACK PRESSURE TUBE CLOGED?
I HAVE REPLACED THE MAIN FUEL FILTER ON THE ENGINE .IS THERE A FUEL FILTER IN THE TANK?SEEMS TO BE FUEL RELATED! WHAT THERE BE A CODE FOR THE PROBLEM WILL A SCANER BE ABLE TO READ IT?MY TRUCK IS DOWN TILL I FIND WHAT THE PROBLEM IS .THANKS FOR ANY HELP! DOWN AND OUT IN CINCINNATI!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
A diesel engine is a heat engine and it needs to be warmed up before you get full power out of it. Let is warm up. Also please don't use all Capitol letters; it is shouting on the internet and is not nice.
dieselnewbie
Check your oil level. Mine did the same thing. My oil filter became loose & blew oil. It was dangerously low.
RSG
Savoy IL
Or, bad slug o' fuel. If it ran fine and then suddenly changed after you refueled? then maybe you got a slug 'o crud??
Brad1103
