Truck starts squealing when pulling load up hill when fan is engaged, only does this loaded and pulling grade, it is a 2005 Lariat crew cab with a 6.0 engine. Any others having this problem.
Your belt may be slipping due to wear of the belt, or a weak belt tensioner. Check the tension on the belt by pushing on the belt. You should not be able to deflect it more than 1/4 inch.
I get the same thing, I did notice it was worse with the A/C running. My belt looks to be in good condition but I will need to do the tension test Daveben stated.
