SPRING QUESTION
pawsranch3
oklahoma
hey yall what size sockets do i need to change the front coils and what is the easiest way to change them. this is on my 2000 f 350 2WD
thanks yall
atk
Moderator
simcoe, ontario, canada
oh, by the way....if it does have coils, they are not hard to change. as for the size of sockets, maybe use your tape measure to measure the size of nuts or bolts....
caryt
Wellington Nv.
Its a 2wd boys..so doesn't it have a coil?
Anyway no offense but coils are dangerous and if you have to ask the questions you did I would highly recommend getting someone with experence to help ya.
Cary
HeavyAssault
King William, VA
BTW the 2wd (READ: Two wheel drive)
trucks have front coils. Don't confuse the 2wd trucks with the 05-current 4wd trucks.
pawsranch3,yes you have coil springs on your 4x2 like a couple others mentioned,I don't know the socket size nor procedure but I could look up the how-to unless you have that down pat;)
FlorWhitfe
