spongy pedal and unknown device
bigrigr
Real trks hv 3 pdls
provo, utah
The best way i've found to bleed that "last little bit" of air out of the system, is to open all the bleeders and just let them gravity drain until all bubbles stop. Start w/those brake guards, then go to the rr wheel, then lr wheel, then both fronts. Just remember to keep the master cyl full at all times. Works like a charm when you do it right, and you don't need a buddy to pump you up! Ha Ha
Brad1103
