mp18d
Uh ohhh
Mr. Shelton, I have what may be some bad news for ya. As a Deputy Sheriff I've taken reports on spare tire thefts over the years. Everyone of them sounds like your story.
What happens is that the bad guys knock off the plate at the end of the cable holding the tire. (I haven't looked at mine lately but I seem to remember Fords are just a roll pin holding the thing together)
The tire then drops (hopefully on to the **** head thief..) but this takes the load off the steel cable, which then "boings" back into the reel housing into a big snarl. Guys naturally assume the darn thing broke and then on some have taken it apart, finding all the loose cable inside the housing. Thats why you dont see any on visual inspection.
A couple have had the cable cut above the tire, I think they didnt have the little locks on the receptacle so the bad guys cranked it down a couple turns and then cut it. But it was obvious it was cut as opposed to worn/frayed. As anyone who has tried it knows, those type cables can be a beyatch to cut unless ya have the special cable cutter, then it's like butter.....
I hope you aren't the vic of some *****hole thief, but if so it may be easier to get the replacement outta your insurance rather than Ford.
Either way, Good Luck!
Mike
Mike
