SP Diesel
spindrift
Central Jersey
Ford_Forgotton said:
SP Diesel has been around for a few years now. They started off by selling 10k mods that they got the instructions from TheDieselStop. Then worked into TC lockup mods and various other projects.
Even the Exhaust sensor dongle and various other "dongles" came from TDS. The only difference was, they found a source to get the right connectors to make it plug and play. But we have since found out you can get the same connectors yourself at NAPA.
Is there something that I should be reading between the lines?
Between the lines or just the lines on the reply I made above.
Just be sure to research what you buy from them. They have a few products that are good but a few that can be done for $100's less.
Ford_Forgotton
Sorry, I guess that wasnt very useful. Lets just say, that was my politically correct way of saying you can do better, but you can do worse also.
I have a pretty neutral opinion on SPDiesel stuff. But then, I have had a few mild "exchanges" with him (sean) over on TDS. Lets just call it a difference of opinions in regards to marketing and forum use.
FlorWhitfe
