Snow packing of air filter/air induction Bulletin
MURR3061
ct
why not a standard
It’s nice of ford not to make this a standard option. It does snow in CT to!
pulin'montana
Michigan
First post in this forum..
I got the grill cover with my job 3 unit, have been using it up here in MI for the last month. I wish it had an incremental opening like the big rigs use. The towing over 32 degrees is real. I had to move my trailer about 15 miles in December, temp was low 20's, so I left the grill cover on. Just after starting out the brief tow, it started a regen. Engine temp and trany indicators looked fine, but the outside air temperature as indicated by the truck climbed to 92 degrees F (sensor obviously under the hood). Regen + tow = heat.
word to the wise: if you tow with the cover on, watch the outside temp.
`08 BlueCrew
Morris County, NJ
they had this problem with the early 7.3's and fixed it in later years. You mean they did it again? Great job engineering there Ford!!!! I guess it doesn't snow up there in Michigan.
Jriltex
