slip joint
VinceJE
Spring, TX
I'm chasing a driveline clunk. Miy driveshaft has rubber boots over the splines with the factory clamps that you have to cut off.
is the slip joint i the drive line? I just wonder if a slip joint not being greased properly could cause some driveline vibration as well?
yes.
as far as the grease goes, the best thing to use is Lubri-plate
iracemine
black and tan
Cheese Curtain
before I head out to the stealership I was wondering if there is a place I can get the boot clamps online instead???????
FWIW guyz :dunno
I've greazed my splines 3 times now.. the first time I did it, I cut the OEM clamps off and replaced them with Band Clamps. 150,000 on'em.. no issues.
Or am I missing something here ??
binuya
seattle wa
I was able to re-use one of mine after carefully taking it off. For the other end I used a zip tie.
iracemine
black and tan
Cheese Curtain
zip tie! heck yeah, I will get some metal ones from the store.
Joe, not a fan of the band clamps. I work with beer draft equipment a lot and find I replace those things constantly with a real clamp fixes most leaks found in a draft system. And I dont want to have that big dumb screw off balancing my drive shaft.
VinceJE
Spring, TX
I didn't find them online. The OEM clamps are a pain to get off and are usually destroyed when you do take them off for the next time. So, I figure a good quality zip-tie is a better option.
;tu Understood.
I'm like'n the Zip-Tie thing too. Guna change mine out today.
JRJ04
Houston, TX
Are the slip joint and carrier bearing 2 different things?
Just wanted to clear this one up...cause nothing has ever been greased under there before on mine and id like to get it done.
Jriltex
