I was pulling my regular gooseneck when i started smelling burning oil and was loosing power
I am stopped now because it wasnt going to go any further, there is oil coming out of the drivers side breather that plugs into the bottom of the rubber air filter housing intake. It is smoking out the exhaust and it is oil smoke. The truck is an 00 f550 with 150K on it, its not the one in my signature.
Anybody think i burned a hole in a piston becasue that is what i am thinking. and if i did can i still run the 180miles home or will i do even more damage?
It will run but it sounds like it only has 6-7 cylinders hitting.
Any thoughts or things i could check would be appreciated. i have never lost a motor before and want to make sure im not missing something simple.
