SilverStar Headlight Bulbs
I just installed a set of 9007 Sylvania SilverStar bulbs and I must say they are a nice improvement. After dark I took the truck for a spin and the light output was a quite a bit better than before. I think I will pick up another set for the Excursion next fall. Anyone needing more light might take a look at the SilverStar :tu:
Max Power
winnipeg/manitoba
The silverstars definitely put out a nice light. The biggest problem you will find is they won't last as long as you would like. They are still worth it in my opinion.
Ford_Forgotton
upgrade your wiring harness and you can almost double your light output. The stock wiring harness is under rated. You lose a few volts, and that makes a huge difference!
A harness upgrade is on my long list of things to do. It took me a year to get around to installing the bulbs..
kwazyca
Sesquipedalian
Redding, CA
Daryl,
I get high beamed now. -mad
Won't the harness make it worse? I turn them down any further and I won't be able to see 50' ahead of my truck?
You might need to turn them to the right rather than down if you are getting high beamed.
kwazyca
Sesquipedalian
Redding, CA
O.K. Minor thread hijack here.
Assuming I have lost where stock aiming was. :(
What is the best aim point for the lights. (I.E: 3 feet up at 50' distance or something)
Thanks,
Tom
