SHOULD I DELETE THE CAT. OR NOT?
WC46
I have a 2006 6.0L with the MBRP cat back exhaust. Thinking of removing the cat. and replacing with the cat delete pipe. In fact it's on order. (AFE) Is this a good move or not? Pro's and Con's? Will I benefit or suffer from this mod.?
rescue911g
Rescue911g
Warrensburg, NY
Removing the cat
Yes remove the cat, I did and not only does it sound better and louder the truck takes off quicker. The only down fall is the turbo is louder, it sounds like a jet at first when you take off then a low tone of a big block sound rumbles you off.:thumbs
good luck George
Northeast Texas
yeah baby ditch the kitten
she is just to restrictive.... although now we are back in texas she has to go back on -mad :( :( but maybe without GUTS :sly :sly
we lost an easy 200 egts with the cat gone
jimmypage
mesa
lose that paper weight it sounds way better with out it
mbrp ? it allows you to remove the cat w/out ALTERING it...
its a 15min job to swap the cat in/out w/ the test pipe (ive done
it 3 times on 2 different trucks...long bed and short bed crew cabs...
one had the factory exhaust the other a full turbo back mbrp...
neither truck took any longer than the other to remove/replace
the cat or the test pipe.
Keller, TX
How come it has to go back on, Robert?:dunno My last inspection, the guy didn't even bother driving or looking underneath the truck once he saw it was a oil-burner. :dunno
06 SuperDuty
Long Island, New York
Delete it, When you bring it in for service just bolt it back in unless your dealer doesn't care. My mechanic at the dealership told me not to bother putting it back in when it comes in for service
TacoCat
