Shorter Antenna Mast for 2004 SD
snicklas
Super Moderator
Staff member
Greenfield, Indiana
Is your antenna really that much taller than your cab? I have an 03 Excursion, 4x4, stock size tires/height and no lift, the antenna is only an inch or 3 taller than the highest part of the body (luggage rack). For me, I use the antenna as a gauge for ceiling height clearance. If the antenna clears, or just barely scrapes, then I know the rest of the truck will fit. When parking in a standard height home garage (7ft door) the antenna does hit, but it doesn't flop and bang around like you are worried about......
I would see if it fits in the garage, height and length, and check on the antenna. My guess is it won't be a bad as you fear.... now if you have CB Antenna(s), they would be worse than your stereo aerial.......
troutwest66
6.0- The Dark Side!
Post Falls, Idaho
I hear what you're saying and my fear was the mounting area on the cowl would weaken from the force of the antenna hitting the door frame. I found a shorty at NAPA for $8 I'll try. So far so good. My CB antenna is a fender mounted whip that is really wispy and it will go in no problem. I can just get the truck in lengthwise, a little grease and a shoehorn! I have some shelving at the back of the garage that I have no where else to put. Oh, well. I won't have to scrape the windshield during the winter.
Pm_guru
