Short or no short
Leslie Moore
01 f350 have a electrical fault with #2 shift solenoid. Wire from solenoid pack to pcm has good continuity. Checked pcm pin #11 for #2 solenoid and all other pins in the pcm connector and found continuity with pin #31 for brake pressure switch. Question is, should this be or not be. Transmission will not shift to second gear even though pcm calls for shift. Thank You for any help.
Correy01
