x2
The pickup in the fuel tank has been the source of a lot of problems. The more common one has been sucking air once the level in the tank gets below a certain point. In my case, the rubber pickup snout actually came off the end of the pickup assembly. So I was running out of fuel even though I still had 1/4 tank.
The "Hutch" mod solved that issue. The "Harpoon" mod lets you fill the tank to the top without it shutting off early.
More food for thought, in the spring & fall when the temperatures swing wildly back & forth, condensation in the tank is common. Especially in tanks below 1/4 a lot of the time. I never saw that the factory fuel filter was that effective as a water separator. When I had to replace my fuel pump, I added a fuel filter/water separator upstream of the fuel pump. I did that as added protection for my new fuel pump. But the water separator had the added obvious advantage.
