SCA additive
Tx_Atty
Master Baiter
Fishin'
Well I finally got some consistent answers - 1 pint per 2 gallons of fluid, so 4 pints. I tested at 2 and it said add 2 more so will take it on faith from now. I will do the flush myself next time and will look at the Caterpiller and others. Getting someone else to do my flush has become as big a PITA as doing it myself. Geesh.
95, you arent worried about the rumored incompatibility of the ELC stuff huh? Maybe I'll look at that next time too.
THanks for the help guys. Im all set now for awhile.
The Fleetrite is supposed to be compatible, its the CAT coolant that has the rumored issues, though its not so much block issues as it is issues with copper, the only place that should present a problem is with the injector cups. That said, there are guys with 100's of thousands of miles with the CAT coolant in place with no reported problems.
I'd use CAT coolant in my rig.
Ricksofla
