Saving $$$$$$
Kleetus
Butler PA
smokemup.com has something like that, but it's a pain navigating their site... I think your overdrive is .67... .067 is like drive with the t/c locked up... lol...
The difference we're going to see here is revolutions per mile. less rev's per mile means bigger tire, and probably better mileage to a point.
One thing I've found annoying over the years is a 225/70/15 tire from brand "a" is generally not the same as the same size a 225/70/15 from brand "b". truck tires seem to be worse for some reason. The old 31 10.50 16 meant it was 31 inches tall, 10 and a half wide and lived on a 16 inch rim. This metric "equivalent" and I use that term lightly, sucks... 225 mm tread width, the sidewall is 70% as tall as the tread is wide, and it's a 15 inch rim (at least that stayed the same...)
You go to the tire store and line up 5 tires all the same numbers, I garuntee they aren't anywhere close to the same height or width... Why?
Wood County Tx
Gear Ratios: 1st – 3.09:1, 2nd – 2:20:1, 3rd – 1:54:1, 4th – 1:00:1, 5th - .71:1
for the tq shift
.071 for od, vice .067.
we need a double od for empty running
our final drive ratio is 2.91 :eek:
Maxtor
Redding
Transmission gear ratio's
Below is a website that has ratio's for our trucks.
Looks like my 6spd manual is a .72 overdrive in sixth gear.
Using my rpm.exe program, it looks like my tires have a diameter of 32 inches
so in 5th gear at 60 mph, I will be at 2331 rpm. Maximum stock torque is at 2250 rpm, so in 5th gear at that rpm, it would be 57.9 mph which would be needed if pulling a heavy trailer up a steep grade. Maximum stock torque to the rear wheels was measured at 473 fpt. at 2250 rpm.
http://www.vibratesoftware.com/html_help/html/Ford/Ford_Transmissions_Main.htm#6 Man
Wood County Tx
notice anything weird? it has a 6 speed as a "torqshift"
and the 5 speed in the 6.0 as a "eaton torque shift"
is that other t/s shift the 6 speed going in the explorer and a few others? looks like0.72 is as high as we go for OD :(
cool site thanks
this is where i steal mine:D
The torque shift is a six speen transmissiion, but two of the ratios are so close it is not worth going thru those gears in sequence. It picks the best 5 speeds for the conditions and uses them.
Kleetus
Butler PA
Yep... I think it picks a different set for the towhaul mode on braking if memory serves me correct.
Wood County Tx
I would concur on the braking,
the down shift to 1 and 2(or what ever is pretty agressive, its very low and you slow down NOW,
i remember reading something about the 1st unlock and 1st locked(tqconv) or 2nd locked and unlocked, and it took to much time to shift, unlock lock then shift
that was a while ago,
i knew i had it somewheres
TorqShift Transmission:
The 5R110W, or TorqShift, automatic transmission is a redesign of the E40D/4R100. Basically, the gear ratio for first gear was lowered from 2.71 : 1 to 3.09 : 1. To get second gear the overdrive clutch is engaged to give a ratio of 2.2 : 1. Third gear is now the same ratio as the old second gear, 1.54 : 1. The TorqShift is advertised as being a 5 speed automatic, when actually it has six forward speeds. On cold engine operation (below 0 degrees) the overdrive clutch is engaged in third gear for a ratio of 1.09 : 1. The transmission will shift directly to sixth from fourth and fifth is skipped. On a warm engine the shift pattern would be 1st, 2nd, 3rd, 5th (direct drive), 6th.
Shift performance has been improved through completely redesigning the control valve bodies. The E4OD/4R100 used an electronic pressure control solenoid to adjust apply pressures to the clutches and band depending on load and throttle position. This would give you soft, slipping shifts on light acceleration and harsh shifts on hard acceleration. There was no feedback to the computer for EPC--it was also assumed that the EPC was operating as commanded.
There were two shift solenoids that would divert fluid flow to various shuttle valves to engage the clutches and band for each gear. There were also solenoids to control torque converter clutch and coast clutch operation. The problem with this design was having to time the disengagement and application of each apply component so as to not have too long of a lag between gears, or even worse, two gears applied at one time. There was also limited feedback to the computer as far as whether the components were operating as commanded, other than electrical faults. The computer could see if there was no RPM change at the shift points and set a code, but it could not determine if the problem was hydraulic or mechanical in nature.
On the TorqShift there are pressure control solenoids that directly control each hydraulic apply component with no shuttle valves. There is also pressure sensors to provide feedback so the computer knows whether it needs to increase current to a specifc solenoid to get the necessary hydraulic pressure, making each solenoid its own EPC. Since the computer is directly controlling and monitoring the hydraulic flow and pressure to each component, there are no lags between shifts and each shift is very positive without feeling harsh.
Another new feature on the TorqShift is the Tow/Haul mode. Unlike previous transmission models, this does not deactivate overdrive and immediately turn on the coast clutch. You still have all five active gears. Tow/Haul is a second transmission strategy in the computer. When activated, upshifts will occure at a higher road speed for a given accelerator position for better acceleration. Also, when releasing the accelerator on an upgrade, upshifting is delayed to prevent shift hunting.
The torque converter clutch will lock up at a lower vehicle speed for a given accelerator pedal position to provide improved transmission cooling. It will also stay locked longer on deceleration to provide engine braking. Engine braking is also provided on deceleration through the coast clutch. On the older transmissions EPC would always be minimal with the accelerator in the idle or coast position. This would result in slippage during deceleration on steep down grades, especially with a load. When the Tow/Haul mode is selected on the TorqShift, the computer commands sufficent pressure to the apply components to prevent this slippage.
Finally, to help maintain vehicle speed when desending a grade and help increase brake pad longevity, the transmission will downshift automatically. If the computer senses vehicle speed increase with the accelerator released, it will downshift to the next lowest gear. If vehicle speed continues to increase, the computer will command the transmission to downshift again. The grade braking downshift mode will be deactivated if the Tow/Haul mode is deactivated or the accelerator is depressed.
The TorqShift transmission uses a new fluid--Mercon SP. This is not interchangeable with Mercon (Dextron), Mercon V, or synthetic Mercon. Since there is no torque converter drain, servicing is ment to be done by automatic flush machine. The external filter--mounted on the cooler lines near the radiator--needs to be replaced at the service. Ford has no service interval for the internal pickup filter. I think it is a good idea to replace the internal filter at the service intervals as cheap insurance against a failure. There is a second transmission filter screen that is part of the valve body gasket, but it does not need to be replaced unless the transmission is being repaired. If a flush machine is not available, the trans pan does have a fluid drain. You can either drain and refill the transmision pan, start the engine to circulate the fluid, then drain and refill again. Or, drain and refill the pan, then remove the cooler return line and direct it to a drain pan. Start the engine and as fluid is expelled from the cooler line, add fluid to maintain the level in the pan. It may be more advantagious to have a someone helping you for this method. Replace the external filter after changing the fluid. The external transmission filter is installed on a by-pass, so it only filters 10% of the fluid flow. I would be advantageous to install a secondary filter to capture any contaminates the factory one misses.
Charles David Ledger; dieselmann©2003
inteliidog
Maxtor
Redding
Glad I have a manual.
My, My, My,
Sure glad I have a 6spd manual.... push in the clutch, shift into gear and go. No trans servos, sensors or other things to go bad.
Brad1103
