Question Runs when first cranked HELP
Ken Harris
LaBelle, FL. USA
When I first crank the truck...it runs rough & then it smooths out. I have a 1997 F250 7.3 L Diesel. I have done everything I know to correct this but nothing has worked. Please let me know if anyone has had this problem & know what I can do to fix it...
Thanks
Thanks
What have you done, or checked so far ??
Welcome to SSD.com Ken, glad to have you here. We have some good 7.3 guys
on here and someone should be able to help you.
Ken Harris
LaBelle, FL. USA
Truck runs rough
I have put a Cam Shaft Sensor, Fuel Pump, A high Pressure oil pump sensor, fuel sensor on top of engine but none of these have helped. It runs rough when it's hot or cold until I hold down the throttle it quits & then it runs smooth. No check engine lights come on.
thanks
Ken
thanks
Ken
Fuel & Air filter good shape ?
Battery posts & clamps clean ?
What weight of oil ?
Yes, all of these items are ok...
Thanks
Plug in the bolck Heater for at least 2 hours prior to first starts. See if that helps ?*
(if not, check the GPR & GP Voltage & ohms)
*(my question about Oil wieght might have sounded Dumb to you.. but IF your oil is Thick & Cold.. due to the wieght, some of your Injectors can be slow about injecting fuel.. until the oil heats up) (viscocity issues) (rough run'n) (even in Florida)
scottu5
