Rough Idle Help!!!
roosterdiesel
Earl needs B100
Amarillo,TX
When was the last engine oil change? Is the oil level low? Is it the right oil? The HEUI engines can act funny with wrong, dirty or foamed oil.
Next guess would be IPR valve or weak injector.
john_hughes
Oil seems to be dirty so i will be changing that tomorrow. If that does not fix it i will be going sensor to sensor to see if i can get a change.
john_hughes
I would try that which sensor is the icp. where is it located? Thank you guys so much for the help.
Got Diesel
Engineering College Boy
Missouri
My guess is it has something to do with ICP pressures. May be spiking up and down for some reason. Maybe hook up a scanner and see what you got for some of your values.
john_hughes
I did change the oil and the cam sensor is next to be put on. I also ordered a icp sensor just for kicks to see if it helps. I am willing to spend some money on it to fix it right.
john_hughes
If i unplug the icp at idle what shoudl happen. if nothing happens it is bad and if it starts getting rough it is good? i havent tried this yet but want to go do it now.
john_hughes
I have a newer powerstroke and i have a different set-up. Is there someone who has a 99 that can take a pic and show me the ICP. I unplugged a plug with a purple seal on it and it had a 3 wire conection.
action4478
Muskegon Mi
Try this...
If the concern is a rough, uneven idle that smooths out after disconnecting the ICP, The problem is most likely either the ICP malfuntioning or the IPR sticking. The manual says to replace the ICP first, but I have found that it is usually IPR. If you ever encounter an engine that runs with the IPR valve disconnected, the IPR is definitely sticking.
The IPR is the three wire plug on top of the left head, right next to the lifting ring...
Ricksofla
