Rough Idle 97 7.3
fordtrucker4life!
I work with waste
SE Michigan
I'm sure you guys have heard this over and over, but I need to figure out what is causeing a 97 7.3 to have a rough and low idle. I will almost stall then pick itself back up and idle, sometimes stalling. Codes that I got were PO344 camshaft sensor and PO603 internal control mod. I have heard some people who replaced the camshaft sensor still had issues. I am calling it a day and hope for some help. :thanks
action4478
Muskegon Mi
Do you have a way to read ICP in real time?....
Try unplugging the ICP connector & see if the Idle smooths out....
fordtrucker4life!
I work with waste
SE Michigan
Thanks for the response guys. Could you tell me where the ICP is located. I have no idea where stuff is on these powerstrokes.
