Thanks!I like your work!
I'm looking to do the same thing but with a heated bowl instead. Any sponsors carry them??
I'm still not sold on the Hutch mod without the ability to provide heat somewhere. And...how can air get *into* the system via the pickup tube (return line) if we eliminate any vacuum leaks on the intake line? What am I missing here?
![Sweet :sweet :sweet](/styles/default/xenforo/smilies/Thumbup19.gif)
Air usually gets drawn in thru the quick disconnects in the fuel line from the top of the fuel tank and the inlet at the fuel pump. Take those two discos out the equation and replace with 30R7 rated fuel hose & worm gear clamps(2 at each end).
After the holidays I'm installing a 26 plate heat exchanger to bring the fuel temps up to warm weather range to reduce engine noise while at the same time attaining a better fuel burn in the cylinders.
Never enough to do!
