replacing the thermostat??
diggla
Alberta , Canada
Can anyone give me instructions on how to replace the thermostat on my truck?
2002 f350 7.3l turbo diesel
dogtrk
Pat
Lower Bucks County, PA
Click on "Technical Articles WIKI" at the top right corner of this page; click on articles, and on Page 2 there's a pretty good description on installing a thermostat. Pretty easy to do.
sirthomas
BlackSmoke Reverend
Southern Colorado
drain the radiator into a 5 gal pail, remove the upper radiator hose, (I found it a lot easier by removing the serpentine belt first) remove the 3 bolt holding the thermostat housing on, (be careful not to drop the rear bolt down behind the water pump, I used a needle nose plier to hold the bolt when it was almost out) remove the housing, pull the gasket out, and remove the thermostat. assembly is reverse of removal, either buy a new upper thermostat housing or use silicone (gasket maker) around the outside or it will leak. you also may want to change to the upper hose for the dual alternator setup, that way if you need to replace the belt you wont have to remove the hose :clint :chiefs
diggla
Alberta , Canada
what do you mean 'dual alternator setup'?? i only have one alternator
If you look at the bracket yer Alternator sets on, just below it, there's a molded area of that bracket where a hose could be. While you have the Thermo removed, along with the upper Radiator hose ? you could replace that hose with one that goes AROUND the Serp. belt instead of Through it.
Yer Call
diggla
Alberta , Canada
Yer Call
ahh i see..
For the thermostat change I pick up the 203 degree model from Dieselsite along with the Black Billet housing.
I applied a bead of Black RTV to give the housing base a good seal.
The top radiator hose for the dual alternator setup is a real plus when you need to change the serpentine belt without removing the top hose especially in the middle of timbuctoo;)
Points to JV for the well done article!!
