DJ13 said:
i am looking at 02 and 03.
Sorry for the delay here – had my 29th wedding anniversary and had to spend time away from the ole computer.
So anyway – 02 models. Here you’re looking at a 7.3 – good long run on this motor. Items to note would be the CPS (carry a spare) and possible oil leak around the turbo pedestal. Trannies were weak in my opinion, so have that looked at. I went through 3 of them in two years – stock. Glow plugs, injectors and such are not regular maint – so don’t be concerned unless they fail.
03 models – you are either looking at a late 7.3 or a new 6.0. 6.0 you should make sure that all the recalls have been done (Oasis report). Check for oil leaks around the injectors and rear of the motor.
Good luck with it.
Ron
