AK Rover
I recently bought a 2005 F250 4x4 PSD with 72000 miles. The last couple days I have noticed a clunk coming from the front driver wheel. When I climbed under the truck and inspected I was able to move the axle shaft in a circle. I suspected the u-joint was bad but the movement is in the hub itself, not the u-joint. My question is whether this is a wheel bearing problem or is the hub bad? Also, can the wheel bearing be replaced without replacing the entire hub?
