Guy Archerd
I have to stompt the brake pedal hard to get the cruise control to release on 04 Excursion 6.0 psd
Check the switch at the top of the Brake Peddal arm, under the dash.. for being cocked or .. replace it. Also.. under the hood.. There is a Recall & TSB on the Cruise Control disconnect.. wireing & switch assembly located on the Brake Master Cylinder. You might call Ford... see if they will inspect you CC issue... due to the Recall ?
OBTW.. WELCOME, to SDD !
