Rebuilding differential
ttt, getting a chatter when hauling a trailer and taking a tight turn under acceleration...or when I have a heavy load in the bed.
gonna sound dumb, but did you change the lube and put the additive in?
orion_134
Woodbridge, VA
oh, I was saying no I haven't changed the fluid since I bought it...think changing fluid could solve this? Seems to me the clutches may have wore down and have lost their tension and the lube may be a bandaid.
oh well you can change it and see as it is not a very expensive test.
In all honesty I wouldn't bother with changing the bearings unless you see a problem when you're in there, if the oil level has been maintained the bearings are good for 500k easy.
