Rear springs????
Chainsaw,the stocker G code springs are 5,400lbs and the F250/350 springs 6,000 lbs(A code) and 6,800lbs(B code)
If anything you'll have alot more capacity for the rear axle but I'm unsure on how much height gain with the A/B codes will get over the G's but I'd like ta know.
I might have to pick up a pair of A's next month and make it a get-Together mod project. :sweet
Bill
Snowman269
MN
Bruce 1954 has an excel sheet with spring rates, capacities & changes in ride height. I'm unable to find it in my files, I'm sure he still has it. I plan on swapping all the springs on our X this spring, the F250 CC rides better, than means the X can ride better.
I have the Ford Fleet Spring capacities sheet but keep forgetting to get the Excel from Bruce :rolleyes:
I thought I had sent a PM to Bruce letting him know of the new Community here :confused:
The actual GAWR for the rear springs is 6,084 lbs for A code and 6,830 lbs for B codes.
The stock springs stand at 5,400lbs or was it 5,250 ;)
cityworldford
