Rear end vibration?
black_cloud_stroker00
GO BIG RED!!!
Bellevue, NE
I installed a 4" susp lift and now I get a vibration in the rear end. 4wheelparts.com said I did not need a carrier barring drop. Any ides?
dieseldork
dieseldork
ca
Make sure the block "if intstalled" is pointed in the right direction, theshorter side should face forward, it is possible that you will have shim the carrrier bearing, the driveline should be straight from the trans or transfercase.
and get it in there before you brinnell the pinion bearings all to snot and have to tear the diff apart....
FlorWhitfe
