Rear Diff ???
Scot
Howell, MI
Anyone know if an 03 350 SRW has a gasket or liquid gasket on the Rear diff cover?
Northeast Texas
mY 02 had some sort of sealant squishing out around the cover as does my 06.
pretty sure they all get some sort of gasket maker type sealant.
Yeap that should be a high temp silicone sealant that's used for the cover.
Clear Silicone Rubber D6AZ-19562-AA (ESB-M4G92-A Specification)
Kleetus
Butler PA
Actually... SKIP the frition modifier... the limited slip will work better and last longer. The additive is to keep noise down, when it's working properly. When's the last time you ever saw one of these work when making a right turn? I'll answer that... NEVER. If it isn't toast already, leave the additive out. flush the gears and the case and refill.
TacoCat
