Rear Diff Problem
rsjohnsn
East Tennessee
Hi all, I went to change the rear diff fluid today and I found what looks to be part of a thrust washer stuck to the magnetic plug. I then pulled the cover and found another piece in the bottom. Now this looks to be a thrust washer from behind a spider gear so I pulled the whole diff assembly out. I haven't took the assembly apart yet because it is a limited slip unit and I haven't ever worked on one before. I did look everywhere and I couldn't see where it has come from and everything is good and tight. Any suggestions as to what I need to do? Can I pull the assembly apart or do I leave that to a professional? Also, where can I get the replacement parts? Are these dealer items only?
Thanks
Scott
It is a straight take-apart operation. If it is a Ford differential, then you will probably get the parts at the dealer. If it is a Dana the parts are available almost everywhere. I have never seen a thrust washer from the spider gears come out before.
rsjohnsn
East Tennessee
I haven't ever seen one either but that is exactly what it looks like. Oh yeah, it is a Dana 80 dually axle so hopefully it will be easy to find and not have to order. Where else could the piece have come from? I will try and get some pics and post them so that maybe the exerts can identify it.
Thanks
Scott
rsjohnsn
East Tennessee
Ok, I got the diff apart and it was definately a thrust washer. After inspection I have determined that I need all new spider gears and the cross shaft that the gears ride on. Remember this is a limited slip diff so the cross shaft is just that, shaped like a cross and all 4 gears ride on a shaft. I will get pics and post them as soon as I can. Anyway, what I am after is where is the best and quickest place to get the parts as I am down until I get this fixed.
Thanks
Scott
Under a 100.000 miles I would think under warrenty, Hope you didn't pull it out to soon.
rsjohnsn
East Tennessee
The local service writer said that the rear axle fell under the 3 year 36,000 mile warranty. I have 77k on the old girl so I ordered the new spider kit yesterday at $400. If I find out that the rear axle falls under the 100k warranty I am going to be extremely upset, which will be minor as to how the service writer will feel.
Scott
RoyBoy
Diesel Dork
central WI
Scott
You got the right info, only the engine is covered to 100k.
TacoCat
