Rear Dif on its way out?
dboyw
Lancaster, PA
Four years ago I had to replace the speed sensor on my 99. Had a lot of fuz on it. I have not had the rear rebuilt since it is still running as good as new. I have towed and traveled a lot since.
JimmyDee
God Bless America
Western Michigan
I wouldn't jump too soon to have it rebuilt. Lots of fuzz is normal. Its one of the reasons I replace the rear end lube at about 20-25k miles. It is usually full of crap. Never lost a rear end doing this. Yours is probably OK. Lots of fuzz is a great way to drum up a repair job.
Jim
Wingdog
Thunder Bay, Ontario
Jim
Especially if you have never got the oil changed before.
If it is not making any noise there most likely isn't much wrong. If a wheel bearing(s) is gone then you will hear noise all the time when you are on the highway. If it the gear set that is going or a carrier bearing then the noise will go away when you let off the throttle. Don't fix it if it ain't broke! :D
