Rear Axle Seal Blown Again!!
PSDfreak
Diesel-a-holic
Chico, CA & Newcastle, CA
Well I got the new seal in. Check the diff. vent and its clear, no blockage...however in my race against beating light last night, I think I installed the seal backwards!! If I remember correctly the "oil side" should face the bearings NOT the differential...For some reason I'm remembering now that I put it in the other way -mad This is really getting old...
-Casey
94f450sd
certified nutjob
plymouth,ma
95_stroker said:
Oil Side should be the side in contact with the oil, which would be towards the differential.
youare half right.the side marked "oil side"goes towards the bearing as that is where the oil will be contacting the seal
PSDfreak
Diesel-a-holic
Thanks, that what I thought....Back to the parts store for another seal, then to the driveway for work in the unbareable heat! :rolleyes:
-Casey
PSDfreak
Diesel-a-holic
95_stroker said:
You'd think after three times you'd be an allstar at this game.:sorry
Not a problem amigo...No worries ;tu ...Yeah you would think so...
I guess thats the problem with working to fast to beat the darkness, you make simple dumb mistakes...Oh well...
-Casey
Ricksofla
