Rear Axle Ratio
metx
I want to know what the rear ratio on my 01' F-250 PS is. It is 2WD and auto trans. I crawled under it and there were 2 tags on the coverplate. One says to use only Synthetic oil and the other says"S 409 H L73 10 5 1A12".
Anyone decipher this for me?
TIA
dboyw
Lancaster, PA
If I remember correctly, it means you have a limit slip 3.73 rear.
Someone will correct me if I am wrong.
Also, welcome to SDD, stick around for awhile and enjoy the fun.
JamieContouris
Proud to be member #2007
Moyock NC
All SRW are 3.73 and you can see that code in the tag (L73) 10.5 Sterling rear.
DRW are 4.10 I believe
metx
Code C1 on the door. Ya'll are correct. 3.73 Limited Slip.
I wanted to know because I am checking into a O/U drive and wonderin how much it will help. Thanks for the welcome. This is a great site for our trucks info.
Thanks,
Keith
Maintain
Platinum Edition
Elkton, MD
All SRW are 3.73
While I don't think this is entirely correct, the majority are. My friend's 2000 F350 SRW CC LWB has the 4.10's I think, if not I'm wrong but the only sure way to know is to check the door #'s! Unless of course you are not the only owner this truck has had, then it's a toss-up!
oil_burner
virginia beach, VA
3.73 is standard but 4.10 is an option .mine was ordered 4.10. only way to know is by reading axle code or doing the math.
HTRDDSL
HTRDDSL
St. Albert, Alberta
4.10 was not an option on a Diesel up to 2002. Only in the 5.4 and 6.8 V10. Unless your diesel was a dually. I still have the original books from ordering mine.
Pm_guru
