Rattle concerns
Lineman
Dexter/Michigan/USA
How everybody doing out there? I'm new to the forum did have some questions i have 2003 f-350 diesel just replaced ball joints and recently put leveling kit on with new rancho rsx shocks sway bar end links still have rattle ove small bumps sounds like coming from driver side front any suggestions?
bigrigr
Real trks hv 3 pdls
provo, utah
Welcome to the site, Glad to have you here. You need to post a repair question in the correct forum for your truck(ie 7.3l, 6.0l) to get the best results for your question. Many smart people won't look in introductions for giving advise. ;tu
carthage, IL USA
I had the same problem with my 02. I replaced ball joints and bearings and still an annoying rattle. I read a forum about a rattle on this site explaining the sway bar bushings being worn out. I put new links and bushings from ford and cured the problem 100%. Now, you can buy replacement bushings from parts house, but I bought the links (have new bushings in them), and the bar bushings that attatches to the axle. New links were $150 and the bar bushings were $30. Well worth the money.
Lineman
Dexter/Michigan/USA
lineman
after some intense checking i found that the headlight assemblies are loose . i'm wondering if a simple adjustment will cure this problem
Brad1103
