random drop to idle
wreckm68
Hot Springs, Va.
I am new to the forum in hopes of someone dealing with my issue before. I have a 1999 Ford F-550 XLT Jerdan Rollback with a 7.3 / 6speed / with 79k original miles. It has been services as it should and babied morew than my children. Here is the issue. Starting about 4 months ago during and only during shifts up or down the engine would drop to idle. It would never die but would not take throttle at all. It doesn't do it everytime and usually only lasts for about 10 seconds. This morning it did it on start up and then once after running. While it will not take throttle the check engine light does come on but goes back off when throttle responce is restorred. There is a old stored code for a cylinder #1 misfire. The engine is absolutely bone stock. Please HELP !!! Thanks Jay
wreckm68
Hot Springs, Va.
also, the electronic idle control did let it idle up while the throttle would not respond and then it was fine again.
Sounds like the Electronic Idle Control maybe ? Is it Fords AIC ? or did it come with the Jerdan Rollback ??
Check & clean the battery cable clamps REAL good. How old are your batterys ? Load (isolated from each-other) checked them lately ?
Try disconnecting the EIC/AIC.. to see if that makes a difference. (PIA for your Rollback ops.. but worth a try ??)
Brad1103
