QuickAir3 or Viair 400P ?
dmftoy1
Lexington, IL
I just had to fix a flat tire on the X while the camper was hooked up and used the little itty bitty cheapo air compressor I had to air up the tire. It did the job, but I was really worried that it would burn out. (I was running it for 5 minutes, with 10 minutes to cool and it took me an hour and 1/2 to build up the 70PSI I needed)
Anyway, I've decided to bite the buillet and pick up a "portable" (not hardmount) DC powered compressor. I"ve narrowed it down to a QuickAir product or something from Viair and I'm looking for good and bad experiences. (Does Viair make a portable heavier than the 400? Like a 450C or 500C in portable?)
Any and all advice is greatly appreciated. (also any sources for compressors! :) )
Ford_Forgotton
The viairs are nice because they dont draw more than about 30 amps.
The OASIS (not portable, but still electric) use start motors and can draw close to 200 amps.
I have the 550c hardmounted under the hood and a 5-gal tank kept at 125psi. I could prolly refill a tire to 70psi in about 5 mins or less.
Ford_Forgotton
You know, that might not be a bad idea. Get yourself one of them portable 5-gallon air tanks, and while you changing/fixing the tire, you could have the compressor hooked to the tank and charge the tank (if its low).
I know a lot of guys are using CO2 tanks, and nitrogen tanks also. Just have to get them filled occasionally, but they hold quite a bit of "air" for things like tires.
kenh
Get a VIAIR 450, 100% duty cycle, mount in a ammo can, add jumpers.
TacoCat
