Quick help with wiring
The wires from the light to the switches are black. The door switch grounds the light when the door is open, thus completing the circuit. The other side if the light is HOT. The hot wire is black with a light blue stripe. Hope this helps.
Teggleston
Las Vegas, NV and Wayne County
Correct DB:thanks and I believe you can knock yhis out in an hour or so it is easy to find in your door seal. Good luck
Tbar
SDD STAFF/Moderator
Maybe I am over simplifying this but why wouldn't you just pull the fixture down from the roof........cut the wire in question and splice in a mini toggle switch in at that point.
Drill the side of the light housing and mount the mini toggle switch in a convenient location.
Tbar
iracemine
black and tan
Cheese Curtain
I think so sine you would then have to install three switches, since he says the excusion has three light banks and that woulld just defete the perpose.
