bserventi
My ESOF was not holding a vaccum, so I replaced the knuckle seal and yellow oring. While I was at it I also replaced the U joint, outer axle and hub. I've been reading tons of posts and looking at tons of pictures of how this is performed. It all seems to have gone back together great. Holds vaccum and all, but I can't get the snap ring behind the auto lock hub that holds the thrust washers in place to seat all the way. I've taken it all apart and back together a couple of times, but it will not seat in the groove. If I put the one washer on it will seat, if I put the Hexagon washer with the round washer it will not seat, and then it obvisouly will not seat with all three on the shaft.
What can I do to get the axle out another 1/8" or so.
Also there seems to be quite a bit of play in the front axle. Everything should be tight since everything is new, but if I reach behind the tire and grab the U joint I can wiggle the shaft 1/8-1/4" inch in the knuckle. Is this caused by the snap ring not being all the way seated??
Thanks
Thanks
