rammertide07
Same shot, more narrative. pictures from cars photos on webshots
Currently working on the FPR shim....
I pulled the compression sleeve back off of the gasket and the gasket fell to fifty pieces and some was stuckl up inside the sleeve and I can't put humpty dumpty back together. Is there somewhere I can buy this gasket or can I put silicone or another gasket forming compound on it and let it dry?
I've also been trying to chase an air leak into the fuel system...could this be one?
P.S. another tip for when working under the hood: take keys out of your pocket. If the panic button gets pressed while under the hood you may get injured due to falling or need a new pair of underwear.
