Question...removed FPR compression sleeve/gasket fell to pieces
rammertide07
Rogersvilles, AL
Same shot, more narrative. pictures from cars photos on webshots
Currently working on the FPR shim....
I pulled the compression sleeve back off of the gasket and the gasket fell to fifty pieces and some was stuckl up inside the sleeve and I can't put humpty dumpty back together. Is there somewhere I can buy this gasket or can I put silicone or another gasket forming compound on it and let it dry?
I've also been trying to chase an air leak into the fuel system...could this be one?
P.S. another tip for when working under the hood: take keys out of your pocket. If the panic button gets pressed while under the hood you may get injured due to falling or need a new pair of underwear.
rammertide07
Rogersvilles, AL
what gasket? the square cut oring? dealer parts. nope and nope.
The gasket to the left of the bronze color nut
Is that a square oring thats on it? I couldnt tell in the pics and the one on my truck is too deforemed to tell what it was.
First time I put the screw in the spring...I built up to about 90psi (started out at 59psi) and then the hose on back of the drain valve blew off. I took the screw back out and dremeled the head of the screw down to where there was no longer slotted, just a flat top. Put it back in....reconnected the hose on the back. Turned the key over and it went up to 60psi...cranked it up. When I looked back under the hood fuel was gushing from the compression sleeve (bronze nut...am I calling it the right thing??)
* get a FPR rebuild kit. or make a gasket from gasket material.
** X2 with dp..
Be carefull puttin it back together. THINK: POT METAL.. all the way.
rammertide07
Rogersvilles, AL
POT METAL?? You mean be careful not to strip anything because its aluminum?
After I got to think about the fuel coming OUT from the compression sleeve...common sense told me air would not be going in.
rammertide07
Rogersvilles, AL
Talked to my Ford diesel mechanic back home and he said he replaces them all the time, and I should be able to get them down at the Ford parts dept.
Soo I'll call around tomorrow and see if I cant track the oring kit down.
Thanks guys
that's what I thought too..
I had a busted nipple on the regulator cover..
rammertide07
Rogersvilles, AL
I think an important lesson has been leaned...when doing this mod, have the spare parts laying around. If you dont use them then, more than likely you will (or someone you know) need them down the road.
