Question Prospective new owner with questions
teleskier
eureka ca
I am looking at a 2001 7.3L crew cab with 63K on it. It is the XLT version. Being new to diesel, what should I look for on this truck as potential problems, recalls, areas to see if they have been maintained correctly etc. It is in stock form with no lift, chips etc. How are the trannys? I heard there were some issues but not sure with which ones or years. Also, what kind of mileage can I expect with no towing and light foot both combined and hwy.
thanks in advance
without a chip, the trans may last a good long while...
watch for you fuel bowl heater to short and kill your truck at an inopportune time
make sure the cam position sensor recall has been done.
other'n 'at... have at it!
From the Baz site
Things To Look For When Buying A Used Power Stroke Diesel
Turbo:
You might take the air tube off the back of the air filter and look inside of it. If there is dirt build up, that is a very bad sign, so are the turbo fins looking sand blasted or bent. A little oily film is normal since the valve cover breather exits inside the tube.
Tranny:
If you buy a truck with an auto tranny, finding out if it's been maintained is essential, as the E4OD is an expensive transmission. Also, (if auto) seeing if the truck has an auxiliary transmission cooler would be worthwhile. For sticks, listen for clunking when shutting off or small vibration while operating. It could be an indication of a dual mass flywheel going out. Many have replaced them with single mass units.
Rear Gear Ratio:
4:10 will pull better, get slightly lower mpg’s and run a higher RPM compared to 3:55.
Coolant:
Ask the previous owner about the coolant - have they been adding FW16 or DCA4 to keep a proper SCA level? It is very important for stopping cavitation. You can get test strips to check the SCA level from NAPA, International, or Ford. I would test the current condition while looking over the truck, the SCA level should be between 1.5 and 3.0. Also, see if it has a block heater (it was an option on 97's).
Front end:
Check the front end for wear, or have an alignment shop check out the ball joints and steering linkage (tie rod ends). If they are shot, it is spendy (all four tie rods are around $400 just for parts, ball joint labor is also very spendy)
Oil:
The questions to ask are how often the oil was changed (at least every 5,000) and what kind of oil they used (diesel rated)? An oil analysis could tell you if there might be an engine problem or not.
Aftermarket stuff:
Seeing if the truck has got an aftermarket downpipe would be nice, a chip, or gauges (pyrometer, trans temp, etc.). Ask about any added items and who installed them.
Glow Plugs/Relay:
Find out if the glow plugs are in good working condition as well as the relay. Ask if either has been changed and when. You can check the glow plug resistance through the valve cover connector. The relay should have power to both large terminals on top when the key is turned on, and one of the terminals should go out before ~2 minutes.
Injector o-rings:
The injector O-rings have been known to be a problem. The new o-ring sets have a pink middle seal. If the truck has an o-ring problem, one of the signs can be a discoloration of the fuel in the filter bowl. There is a drain on the passenger side front of the filter bowl for draining water (the filter is also the water separator) and you can catch some of the drained fuel in a jar – it should be dingy yellow and not blue or dark.
Leaks and Drips:
You can check the valley between the heads of the V8 for moisture and/or fluid. It should be dry not wet. Most leaks will run through this valley and down the back of the motor dripping off by the tranny/engine coupling.
VIN number:
If you take the VIN to any dealer, they can tell you when it was built, when it went into service, and some of the work that might have been done on it. You can also run prospective VIN's through Carfax.com to see the title history.
jestersv
7.3 addict
waterloo il //stl.louis
crumm, if i'm not mistaken the 99 and up manuals did not have dual mass flywheels at least my 99 doesn't, didn't. I put in a luk. as far as all else crumm,s on the right track 7.3's are good trucks the low miles puzzles me more than any thing else. not using them is harder on them than working them are those city miles camper,or boat towing miles the city miles would worry me more than towing at least it will get warmed up.
Zookie400
I WANNA GO FAST
wallingford, CT
ball joints would be the one thing i would stress on a superduty. crumms list covers the rest. 7.3 is pretty damn bulletproof. most transmission troubles on a stock truck stem from lack of service, they like fresh fluid.
Ford0273
Littleton, Colorado
fluids, fluids, fluids...If the fluids have been maintained and you continue to do so you'll enjoy the truck for many miles to come. I bought my 02 almost 6 years ago and put 130k of the 165k on my truck. It's my first diesel and I wish I would have had intrest in them sooner. The power and reliabilty is amazing. Have the truck looked over and make a deal on what is found. All trucks will have drivetrain parts wear out eventually, but these things will go forever.
FlorWhitfe
