Pros and cons of Manual VS Auto
Montana
I'm Diesel Stupid
Dickinson, Texas
What are the pros and cons of the 2. Which would be better for long term reliability. I am under the impression that manual would be more trouble free and have less breakdown. Is that the case??
Thanks, Rob
Zookie400
I WANNA GO FAST
wallingford, CT
manual pros:
-long term reliability, the only problems i have seen are clutches, and leaks.
-they handle gobs of power with no modification other than a stronger clutch
downfalls to the manual:
-you have a stick in the cab taking up space.
-you lose turbo boost every time you step on the clutch
-they are slower off the line from a stop
-if the truck has very tall axle ratio, it can get tricky towing heavy loads in confined places.
auto pros:
-less work for you
-more room in cab
-jump off the line, loaded or empty.
-constant boost for hard accelleration
-stump pulling torque
-PROGRAMMABILITY!
-many many many upgrades available to make the ultimate towing or racing machine
-can be locked into 2nd to under power the engine
cons:
-they wear out, faster with higher hp.
-very expensive to fix/replace
-wear out brakes faster
-not much engine braking (in stock form)
-cant pop start the truck.
im sure others will have much more to add, or disagree as much of tranny choice is opinion dependant.
FTG-05
North Alabama
Manual Pros:
- I love rowing through the gears
- Autos are a dime a dozen, if and when I sell mine, the manny types will be lining up at my door!
I hear this from a lot of people. Yes, the boost gauge goes to 0, but as soon as I hit the throttle it goes back up to 25:dunno
I agree. And when down shifting.. you can REALY nail some Needed boost.
I also like being able to shift gears when I want, in anticipation of what needs to be done, before, after or during the need.
But in the end, it's to each, his or her own choice.
ckamp52
ckamp52
italy,tx and stephenville
as mentioned above it is all a preference choice and what you wanna trade off in the pro and con section... my 05 is a 6spd and its pretty good i just love to change gears it make me feel cool...hahaha:cool:
paulkeith
Da A
if you can afford a badass auto tranny and to rebuild it as necessary, they're cool enough. i think i could appreciate the very low effort cruising with an auto. the 1.5' throw legpress that is my clutch pedal can get old in stop and go traffic.
what i do not like about autos (aside from $4k rebuilds every 75k miles) is not being in complete control. even if you have a very good box, you still have to floor it and wait (even if its a very short wait) to get it to respond or downshift if you need quick reaction. i like the ultimate selectability of my 6spd, even if that means coming off the line slow. i didn't buy this truck to race. i can handle 600 hp with just a $1.5k clutch...not that i'm ever going to get to that point.
honestly, if i was rich, i'd have 2 superduties, one of each variety. if i have to pick, i pick my 6er.
real trucks have 3 pedals, 2 sticks, and no spark plugs.....too bad mine has gaytown esof.
later,
Paul
Zookie400
I WANNA GO FAST
wallingford, CT
i cant wait for an infinatly variable transmission to come out on trucks. it would blow both manual and auto's out of the water.
FlorWhitfe
