proper procedure!!
F350DRW1
Waylon Fan
N.J.
Hey folks,
Concerning the oil change process, before you put back the new filter you are to add a quart or litre ( US quart , Canada litre) to where the filter is so that you don't start up bone dry. So 13.5 to the engine compartment , and one in the oil filter compartment.
P.S loved the navy thing :roflmao :roflmao
Jim up in Canada
What keeps the oil in this cavity? When you loosen the filter you loose the oil from this area, so how does the 1.5 quarts that you would add stay there? -popcorn
Jim up north
Lachute Canada
oil procedure
A little note to what I wrote before , I should have mentioned that once you put back your new filter , then fill it up SLOWLY you will see that the oil filter will absorb your oil and the cavity will fill up. Fill till about 3/4 of the way and you will notice with the filter absorbing it will equal about a quart .
Jim up in Canada.
P.S. if I'm not mistaken this is written about somewhere , any follow-ups would be nice .
See ya
Elk
Colorado
Doesn't work for the 6.0 for me. I can't get the oil to stay in the cavity.
Jim, is there a trick to this?
The drain valve closes when you screw on the filter cap. Can't get oil into the filter with the cap on.
DragonSlayer
Pensacola FL
WOW, all I can say is WOW!!! Did not know I was doing it wrong. Thanks for the info........I really need to read more stuff out of dat der owner manual.:doh:
F350DRW1
Waylon Fan
N.J.
I change the filter, then drain using the Fumoto valve. You can change the oil on these trucks w/out tools if your grip is up to the task.
Kleetus
Butler PA
Jesus... remind me never to shake your hand if I ever meet you.. I can get the filter housing by hand, but the drain plug would be a bit of a grunt... unless you use your teeth! :roflmao
no-red 6 0
Senioritis
southmetro MN
to whomever, thanks for bumping up this thread. i need to change the oil here soon and would have not done it properly - again... duh
mwalls- good to see u are still alive, got your message.
F350DRW1
Waylon Fan
N.J.
Well, I did mention I have a Fumoto valve...no tools required for that.
Ricksofla
