Problems with powersteering, and brakes....not fluid
forumpete58
Kansas City, MO
I'm having some serious problems with my power steering as well as brakes. The power steering has all but gone out making this thing all but impossible to park and has a serious whine whenever I try to turn it. Also the brakes have a similar whine whenever the pedal is pushed beyond a certain point. Fortunately they work fine though. I checked both fluid levels and they seem fine, they may be a bit low but not serious.
Thanks!
01platinum
Go VOLS
Murfreesboro, TN
the brakes and steering both work off the power steering pump, possibly just a bad pump or fluid contaminated,
Zookie400
I WANNA GO FAST
wallingford, CT
:eek: check:
-PS fluid level and quality
-PS hoses for kinks, or any other restriction
as 01platinum stated, the pump could be bad but you want to check everything else before you throw an expensive pump in there.
forumpete58
Kansas City, MO
I installed a new pump and the situation is certainly better but the steering still a bit hard; also the brakes and steering still have a whine.
farmboy99
Napa
I had to put a new pump on my 99 sd and the brakes where still acting weird for a week or two afterwards...
cityworldford
